Posted 9/9/2008 11:07 (#455810 - in reply to #455698) Subject: Re: JD row sense on 60 series???
NE SD
Rowsense requires SF2 accuracy. Therefore, whenever you have your autosteer system in your combine with the corn head on, it will be running on SF2 whether you have activated the SF2 or not. If you have not activated the SF2, once you take the system back out of the combine, or start using a platform, it will revert back to SF1.
