Litchfield MN. | I have been running the S3, e-drive and baseline on a CAT 55 this spring. With the Baseline I get probably 2-3" accuracy,haven't compared to waas only. We are in strip till and were hoping the accuracy would be good enough and it probably is. But since buying the Outback system I have found out about the Coors net work that is here in MN. and am seriously considering swithing to that system to improve repeatability needed for striptilling. Haven't made the decision yet but if I switch I would have an S3, e-drive w/Cat55 Hyd. kit, and baseline for sale if you are interested. My e-mail is in profile. The e-drive & Baseline are one year old and the S3 was bought this spring.
The update that Outback is working on is an updated E-drive but if you don't need max accuracy and especially putting it on a tracked tractor you should be happy with the current system.
I really like the S3, I didn't notice glitches in mine worked fine. Nice aplication map and touch screen controls. | |
