Pasco WA. | Tomorow I am going to start planting alfalfa. Running in center pivot pattern pulling a drill behind a cultipacker. Ez500 with XP. Do I set the implement distance behind tha antenna to the actual distance or will it even matter? I will start at the pivot and work out. As I go out on the pivot the drill will not drift as far inside. However I am going to set up a small overlap so that I won't have any skips. In theory if the tractor moves over the proper distance each pass the drill should be in the proper place. Anyone have any experience doing anything like this? | |
