Watford City, ND | Yes...but I'm not sure what all you'd need. Maybe you only have to replace the seedstar bow with a SeedStar 2 box? GS2, of course.
I cut and copied this you you.
_______________________________________________________________________________
Compatibility of SeedStarâ„¢ 2 equipped air seeding products with GreenStar 2
John Deere Air Seeding products for 1910 Commodity Carts with S/N H01910X730000 and above now come standard with SeedStar 2. 1990CCS machines which have the option of the SeedStar 2 system will also enjoy the same GreenStar 2 technology.
The GSD 1800 will allow the operator to see:
Fan speed
Ground speed
Shaft speed of front, middle, and rear meters
Bin levels
Area seeded
Increase/decrease seeding/fertilizer rate on-the-go from the tractor cab with SeedStar 2
Main and tank meter clutches (on/off)
In addition the operator coverage maps, flow monitoring, tractor speed.
If the operator would like to run prescriptions or field documentation applications they will need to updgrade to the GSD 2600. Dual displays are no longer necessary.
SeedStar 2 is only compatible with the GS2 family of displays. These applications will no longer work with the GSD4.
SeedStarâ„¢ 2 blockage
GreenStarâ„¢ 2 display
SeedStar 2 blockage works just like SM500 blockage. As you can see from the screen shot you are able to view blockage by row. A red box would indicate the row is plugged.
Unlike the SM 500 the SeedStar 2 does work on both single and dual rank models.
On dual rank machines the sensor is located after the Y splitter. Single rank machines have a sensor installed on each individual row.
