1 1/4 mile south of Tedbear | I've done it several times.
Pin #3 at the starfire needs to get to pin#3 at the Viper DGPS connector.
John Deere has a TEE cable. The Tee will plug between receiver and tractor.
On the other end of the cable is 2 radar connectors & a DB9 serial connector.
I can't remember the part #. If you call me at L&D on monday I can find it or I could make you a cable.
Once you have the viper connected you need to configure the receiver to output GGA,VTG,ZDA,@5HZ. |
