Posted 8/20/2008 00:56 (#438981 - in reply to #438885) Subject: Re: Trimble Planter Control
Rochester, IL
probably not going to be able to use the rawson because the FMD is using DJ software which will be primarily a PWM out put control and servo if you really wanted to. I haven't used it personally but I know the DJ Intelliage side and I know the FMD steering side just haven't used them together.
