Posted 8/18/2008 08:33 (#437677 - in reply to #437231) Subject: Re: Cab access on LF 7X30 Tractors
Guelph Ontario Canada
Roof will likely have to come off, then you will be able to run a wire through the grommet and down the corner post. You might have to loosen the front corner of the headliner to make things easier.
