NC IA | Doing some research - don't have access to a lot of Agco info so I'll ask here.
I've gathered that the Agco GTA Console II can Variable Rate Plant when hooked to either a White or properly equipped Great Plains planter.
Does it also have the capability to "talk" to a serial-port equipped controller like a Raven, Rawson, or other for VRT fertilizer or N application?
What format does the GPS rec file need to be in? Can it handle a shapefile or is it a proprietary format?
Thanks for any help.
Ben | |
