| I have put a kit in myself. If you have background with taking apart an engine or something like that you would probably be ok. For an 8310, you are probably looking at a day to a day and a half. Do you have a greenstar harness in there already? If you don't you will need to put that in as well. You will need access to the internet because at the end you will need to get into diagnostics mode and register the ssu and calibrate the ssu. If you feel that gets too much the dealership mechanic will be able to do it in less than an hour. Any questions let me know. | |
