n.w. iowa | tmecham - 7/23/2008 11:28
ScottPA,
You are correct. You can use your GS1 setup that you currently have. You don't need the Rinex screen. mojo can plug and play right into your GS1 controller and still maintain the same functionality that you utilize, just as you would with the GS1 as a stand alone. Difference is you get RTK accuracy, Glonass satellite option if you want it, and Virtual Wrench.
Thanks,
Trevor
I currently have the gs2 , my 8420t is wired for steering but not activated would I need to pay j.d. to activate the steering or would the mojo being pluged in do the steering? Thank's |
