Posted 7/14/2008 02:44 (#415111 - in reply to #415056) Subject: Re: Autosteer, accuracy and speed which system?
Sunnyvale, CA
the EZ=Steer when it is connected to an EZ-Guide 500 works at an update rate of 50 Hz instead of the EZ-Guide Plus update of 5 Hz. This 10-fold increase in update allows the EZ-Guide 500 to do a much better job holding the line at higher speeds. See if you can get a demo for the EZ-Guide 500 from your dealer. You will need the T2 upgrade for the EZ-Steer controller and a firmware update to operate with the EZ-Guide 500.
