Chillicothe, Missouri | we have foam filled tires on our 1845C and we love them, I use a Tree Terminator on it regularly and it prevents countless flats as I am shearing honey locust and hedge trees. the only disadvantage that I am aware of is the weight. it takes at least 2 guys to load one of these tire into a truck. therefore, they put more strain on the drive chains, but we haven't had a problem in 4-5 years. you want to put good tires on it, not cheap ones as it is kind of expensive to have them filled, and you have to cut the tires off the rims once they are worn out.
hope that helps
Brandon | |
