Queensland, Australia | Am having problem with MT755 linkage very slow to lower. Drop speed is set at 100% but is still very slow. You can turn it back to 10% and it drops at the same speed as 100%, but below 10% it does respond and slows the lower you go with the setting. Seems to drop faster if you use the depth stop handle instead of the lower switch. Plow attached is about 5 ton. Any suggestions or at least a heads up on how the system is controlled so I can start to nut it out. TIA | |
