Northwest, Ohio | Our 5130 CIH has variable flow on the valve stack, but I'd like to have it in the cab since I run a Hydraulic sprayer pump and like to adjust now and then. (good pressure but not blow off hoses). In cab controls are not availabe as a kit anymore, just as parts.($) I'd like to check with some salvage yards to see if it is available for cheap.
The kit is two levers, spools to pivot on and linkage to the valves. The round knobs are removed to be replaced by D links.
Any ideas on who to call? | |
