My 4630 has a bad leak where the top tank meets the header plate. It is is an easy place to get to, but I can't remember what kind of sodder to use. I have also heard you can't fix a leak here because a leak here means the header plate is warped and unfixable. I am going to give it a try, but what should I use? Mitchco.
