Hagen Brothers farms,Goodrich ND | Got a Shark tooth shredder grate to hopefully cut up pea and bean straw for a better seedbed next season. a question for those that have used this device, is there a best position to mount this thing, should I use it to replace the front ,center, or rear grate ?
Also using my faithful old 1482 as a parts donor for the 1480 that is replacing it. Spec rotor with Gorden bars, Axceller, Harvest concaves, Harvest quick tach cover plates Harvest fixed air foil chaffer and modified shoe sieve. all go in the new machine, plus all the other parts are spares for the 1480's. I hated to scrap the good old machine, but it's parts are worth far more than the complete unit.
Axceller had only done 100 acres of peas, so is barely starting to wear the paint.
Anyone need new pinto bean concaves and screen elevator doors for a 1480? The new combine came with that stuff with just a few acres of use, Don't think I will ever grow pintos.
Edited by Jon Hagen 6/27/2008 22:57
(Shark tooth shredder..JPG)
(Organ donor.JPG)
(Axceller after 100 acres.JPG)
(Spec rotor std bars.JPG)
(Spec rotor with 12 Gorden bars..JPG)
Attachments ---------------- Shark tooth shredder..JPG (69KB - 256 downloads) Organ donor.JPG (56KB - 269 downloads) Axceller after 100 acres.JPG (80KB - 248 downloads) Spec rotor std bars.JPG (62KB - 250 downloads) Spec rotor with 12 Gorden bars..JPG (61KB - 273 downloads)
