Posted 6/27/2008 22:46 (#405913 - in reply to #405853) Subject: RE: Liners
Central Mo
There is a liner that goes around about a third of the circle. It will develop a groove in it, if you haven't replaced them you might look. I had oneof the little pins shear and then spun it tight. Ended up being those liners. I replace them every year now and don't use graphite. Cost of replacement is about the same as the graphite I was using.
