Posted 6/23/2008 23:28 (#403417 - in reply to #403400) Subject: Re: motorcycle for checking fields
Mid-Missouri
I have been using a 79 Honda 350 xl. Good power, big bike for me though. Simple, points set-up. I would rather have a newer, smaller one but it sure works fine. Try to get the off-road tires if you are going to use it more in the field. I would recommend a four stroke and usually you can't go wrong with honda.
