Saronville NE | On my 5250 you will be going along raking hay or baling today anyways, and you will shift up a gear and its like it gets inbetween gears and the transmission light on the dash comes on, and if you push in the clutch for 5 seconds it goes right into gear and will work just fine, it only does it every so often, any clue as what this is or whats causing it? Also once ina while you got to put it like 3rd gear and it doesnt go into gear the disengage clutch light is on but put it back in neutral and back in gear again and the light goes off, have hrd that mentioned here before, whats the deal there and what do I have to do to fix it? Love the tractor, just couple little quirks I need to fix. TIA | |
