Quincy, IL | I'm having trouble starting a bale. (JD 530) Sometimes it starts feeding great and other times it wants to build up between the teeth and the roller. Grass hay good and dry. Do you think the teeth are getting worn out or are the bars on the roller getting a little rounded and not getting a hold of it?????? I remember awhile back a guy talked about welding on the roller bars, think that would help?????
Thanks!!!!!!!!!!!!!!!!! | |
