Posted 6/17/2008 22:28 (#399744 - in reply to #399720) Subject: Re: Case 8010, GPS to case monitor
roaming
There is no harness to go from the 252 directly to the 4-pin Deutsch connector in the grain tank, so you'd have to build your own or run it in via RS232. For RS232, you need to install kit 84083373, and then 252 data cable 87298129 with adapter 87302445.
