Posted 6/13/2008 23:24 (#397061 - in reply to #396678) Subject: RE: hiniker Hz/Mph Setting
SW Ohio
On my Hiniker 8100 I used 17hz from my EZ guide 500 to a 14.7 inch wheel size. If that doesn't help you try starting with 17hz and put in some numbers and see what your speed looks like. Adjust up and down until it matches what the 250 speed reading is. Hope this is some help.
Good Luck,
Dave
