Central IL | Yes the GS2 2600 will be the only monitor that you will need.
My neighbor was supposed to get the electrical clutch row shut off from Deere and Deere could not get enought supplies for them. It appears to be similar to Tru Count except it uses a actuator not a solenoid, only .5 amp requirement per clutch. I would be shocked if they were available for 09 even on a limited availability.
If your new planter is the Pro Series I would get the Deere plates for sure. If you are getting the 1.6 bu hoppers I may consider Precision due to the Deere is slightly more work to adjust on the 1.6 box. | |
