West Central Ohio | I have an Ag Leader 2000 on my 2166. I do not have the GPS unit with it. Have used it for about 5 years. For a basic monitor, I have been very impressed. Use it mainly to compare yields from different fields, varieties, etc. If you take the time to calibrate it as described in the manual, it is very accurate. You should be able to find a used one fairly cheap. It would be a could a good way to get your feet wet in precision ag w/o spending a bunch of $$. | |
