Posted 5/29/2008 08:22 (#386875 - in reply to #386601) Subject: Re: Precision Planting Data
There are times where the Shapefile conversion does not work for some reason. The earliest hint is when it takes it 2 seconds to convert the file (time meter at bottom of page) If per chance it does work, then it is a shapefile. Go to "import" in Apex and select file. It will show up as a Management Zone under your maps.
