Search Forums | Classifieds (100) | Skins | Language
Inisght stops recording
KevinFButt
Posted 5/26/2008 21:14 (#385262)
Subject: Inisght stops recording
North Central Iowa
Planting beans and corn with 2 different planters hooked to JD tractor and using the Insight to log planting data. Everything works great except every now and then the Insight will stop recording. The green light is on the screen saying it's recording, but acres stop and nothing is plotted on the map. We have GPS signal and it maps across position across the screen like normal, just not recording the data. After we shut down the Insight and start it back up... everything will work fine until it happens the next time.
Does anyone know what may be the root of this issue? We've had it happen on both planters so we've eliminated them from the variable.
Any help would be great.
Thanks in advance.
