| Keep having bridge fault when trying to enable ez-steer. Have reset override sensitivity up and down and checked connections, but found nothing obvious. When disengaged the steering motor free-wheels with no resistance one way and has resistance the other way. I have disconnected power and the motor still has the resistance in one direction. I have to disconnect the steering motor from the ez-steer controller before the motor free wheels in both directions. System worked fine for previous days before this error occured. Any advice appreciated. | |
