Search Forums | Classifieds (100) | Skins | Language
Insight seed command/hyd vrt seed drive
notill89
Posted 5/26/2008 09:02 (#384933)
Subject: Insight seed command/hyd vrt seed drive
South Central Nebraska
Can you control your variable rate hyd drive with the Insight on a Deere or White planter without the monitor or control box that came with the planter? The Agleader website doesn't seem to show which drives it supports. Will it control a Rawson without the cab box? What brand of hyd drive does a Deere or White use?
Thanks
Edited by notill89 5/26/2008 19:18
