North west MN | Set a minimum flow in gallons per minute by looking at a spray chart and see how many gpm your tips put out at the minimum pressure you want to keep then multiply that by the number of tips you have. To set the minimum flow you go the configuration you are using then highlight it and select edit and it will allow you to set a minimum flow. I just set my sprayer and it has 54 nozzles that are 03's they put out .21 GPM at 20 pounds of pressure so I took 54X.21=11.34gpm for a minimum flow | |
