Search Forums | Classifieds (120) | Skins | Language
4720 sprayer tank vol. countdown
JustinW
Posted 5/25/2008 14:15 (#384495)
Subject: 4720 sprayer tank vol. countdown
Kenosha, WI
Has anyone ever had the tank volume that you entered count down three times as fast as it should. Actual tank volume is still correct even when spray star read 0. This only happened to me the one time the other day and after I reset tank volume actual number, it counted down to zero again within about 5 minutes. The entire time the application rate (GPA) was correct. Several other times I have had problems with the rate not locking on correctly, but tank vol. always counted down perfect. Anyone else ever had these issues? thanks, Justin.
