Jersey Shore, PA | I would not be able to go without markers here in C. PA even with SF2. I still get too much drift. If I leave for more than an hour or so, I drop the marker so I can shift track back on center again when I get back. Curve track IMO is not very reliable. I use the markers when in a curve track field and it is usually not near enough to the line to let the tractor steer. Problems getting close to tree lines and losing signal around here. Don't know what you were told, but I wouldn't believe little/no drift especially w/sf1.
Scott | |
