| I'm running the accu-boom on a Viper and have mixed feelings about it. I think it will be great if I make up some boundry maps for next year but with the Accu-boom turned on you can't use anything but the master switch on the Raven which makes it a real pain to try and spray around waterways when opening fields up. For next year I'm going to put the Viper on the four wheeler and map all the fields that way so I can just load up the field map from the memory card but I haven't had time to do that this year.
