Insight - Direct Command w/DJ system
ironhorse
Posted 5/20/2008 00:47 (#381300)
Subject: Insight - Direct Command w/DJ system
Would like to know what is needed to replace a DJ monitor/controller used with DJ heat exchanger.....Have the Direct Command, but would like to only transfer the Insight w/DC control box and NO modules, etc.  What would be needed?  Is it just application rate module, a DJ harness adapter, power cable, relay? More?
At the least, can I just use an Insight and monitor/log rates applied w/out controlling it.  If so, what would be needed?
If part numbers are known I would appreciate that too.....not absolutely necessary though.
Thanks for any help.
