Lee Co | last nite while planting w/ the 500 on omnistar correction when I turned at the end the screen said I was off about 2 feet from the marker. so I nudged it back while moveing. I get to the other end and it's off 2 feet again. so I reset A-B line, next round same thing. antenna is in center, worked fine first 2 days, measured markers to make sure one didn't move, WHAT AM I MISSING? I called the salesman he suggested shut-down and start so I did this also but is still off. If I put a off-set in it might correct the problem but it won't be correct so why band-aid the problem I would like to find problem and get it corrected. anyone else have a similar problem? | |
