NW NSW Australia | We have had the same issue and had the hall effect sensor in the flow meter replaced and this seems to have solved the problem, the dealer also has cleaned some sometimes and that worked.
You can clear the code without shutting down by inserting a fuse in the diagnostic slot and going to the SSU fault codes and cycling the hazard light switch. I found this was the only way to keep going, without be driven totally batty when the sensor was having a bad day. I cannot remember the sequence of high beam and blinker cycles you need to do to get to SSU, but if you would like to know I can sit in the tractor and note it down. | |
