| Has anyone configured a John Deere GS1 or Brown Box to hook to a Raven GPS. I'm having trouble doing so. I get signal into the GS1 if I'm in Field Doc Planter Mode, but would like to be in Field Doc Connect Mode. I want field Doc Connect in order to connect to a Rawson drive and run my prescriptions through the GS1. Deere will accept the 3rd party GPS (Raven) to do most any applications/modes except the field Doc Connect and JD states you need there starfire globe to make this work. Has anyone found a solution around this problem?
