Posted 4/30/2008 23:53 (#368963 - in reply to #368934) Subject: Re: 85E EZ steer adjusting.
North west MN
<p>Make sure the T2 controller is mounted so it can't vibrate or move, check to see if the foam drive wheel isn't slipping, I am installing one in a cat tomorrow I can let you know how it turns out. I know on wheel tractors I end up with aggressiveness up around 115 to 125%</p>
