Classifieds (5)
Spraying Atrazine?
Crop Talk
Hawken Cougar
4/23/2008 21:47 (#363916 - in reply to #363898)
RE: Spraying Atrazine?
So. IL
What form of atrazine do you have?
The liquid is usually a 4L formulation which provides 4 lbs. atrazine per gallon or 1 lb. per quart.
The dry formulation is usually a 90DF which provided .9 lbs atrazine per pound of dry product.
If you have any green growth you might consider using some crop oil with the atrazine.
Spraying Atrazine?
harrmw
: 4/23/2008 21:20
agrarianyuppie
: 4/23/2008 21:29
Hawken Cougar
: 4/23/2008 21:47
HT67
: 4/24/2008 06:42
