| I ran with the easy steer yesterday and really liked it. I pretty sure it wouldn't work for planting unless I got it tuned in really good. I'm running into a little oscillation due to the inertia of the booms. Especially on soft ground, when the ezsteer makes a significant correction it gets the 100' boom winding up and pushing the machine around a little. The EZS tries to correct and tends to over correct. If the ground is firm/flat, this doesn't happen much. So far I'm just following the guide and adjusting steering angle, agressiveness and freeplay and it's getting better. Have others run into this and was there a particular adjustment that helped more than others?
Thanks,
Pat
Ps: this is on a gallenberg (willmar eagle) sprayer | |
