664 rogator curcuit board
RodJ
Posted 4/18/2008 13:16 (#360627 - in reply to #360574)
Subject: RE: 664 rogator curcuit board
NW Kansas
The circuit board in the battery compartment is the same as a JD combine board. I would check at a salvage yard for that and see what JD wants for one. I'm not sure on the boom control board. You might see if you can find a serial number on it. I know the boards will corrode that are in the battery compartment but haven't heard of the ones in the cab causing trouble.
