Posted 4/19/2008 22:38 (#361523 - in reply to #360265) Subject: RE: Density of ag lime?
Effingham, IL
The aglime around here usually runs close to 90 lbs./cu. ft. That's dependent upon the fineness of the grind and the amount of moisture contained within the lime, but 90 should be pretty close.
And yes, a fertilizer density scale is fine. That's all I've ever used.
I don't have an answer for 80-89 lime. Not even sure what it is exactly.
