Search Forums | Classifieds (8) | Skins | Language
EZ-Steer 500 questions
22 inch row
Posted 4/17/2008 23:41 (#360245)
Subject: EZ-Steer 500 questions
south central Minnesota
Just installed new 500 and ezsteer. It is wet out so I am trying to use our driveway as the a-b line to see if it works. When I drive toward the line it will not engage on the AB line it says "can not engage ab line" is this normal? This is on a 85d, what do you guys use for your antenna offset since they use 59" for the track lenght which really isn't right? Also do you cat guys leave your drawbar swing we alwalys do and I am wondering if that is going to make a difference?
