SW IA | Here is the report that came back. The product is Nachurs 9-18-9. This is our first year using starter fertilizer. Several others in the area use this product and number, and have had no problems with this. Our plan is to put 5 gpa using the totally tubular setup. The file is a PDF, so not sure if it will show up..... Thanks for the help. I'm thinking next year, (If we make it through this one!) of using a Poly/Ortho mix instead of 100% ortho, going by what I have read from past threads on here.... Any thoughts, I'm really confused now!
Also, is it typical for the percentage of N, P and K to be off that far.... the K is off almost 10%.... (think I did the math right ?!) I know it won't be perfect 9-18-9, and I realize that it is probably within their tolerances. Just wondering.
Edited by ERIC1466 4/18/2008 00:55
Attachments ---------------- Report.pdf.PDF (61KB - 755 downloads)
