Search Forums | Classifieds (42) | Skins | Language
E Z Steer settings needed
roadrunner
Posted 4/17/2008 01:14 (#359663 - in reply to #359384)
Subject: RE: E Z Steer settings needed
See if you have T2 controller orientation box checked right when you go through the EZ steer setup. Correct answer is which way the wires are facing as they come out of T2 box. Chance that's your problem if that isn't answered right. Which way is your box mounted now and which way are wires pointing as they come out???
Edited by roadrunner 4/17/2008 01:16
