Search Forums | Classifieds (83) | Skins | Language
MX270 Hydraulic PSI AutoPilot, Insight
530Quad
Posted 4/16/2008 22:02 (#359495 - in reply to #358772)
Subject: Re: MX270 Hydraulic PSI AutoPilot, Insight
I have run across the same issue before and their is no way of setting the steering standby pressure up. The steering is run by a gear pump and what kind of shape your pump is in dictates how good your low pressure is going to be. The easiest way to do this is to plumb your pressure and load sense lines into power beyond on the main hyd. If your tractor does not have power beyond, it can be installed. That was the only way to get the Autopilot to work correctly on the tractor that I seen.
