Centre county Pennsylvania, USA | Antenna swap test was not run yesterday, it's still on to-do list. Tractors were needed for field work now that spring has sprung and antenna swap test requires more tractor down time. Didn't want to risk hot plugging antennas, that means power must be cycled at least twice for antenna swap test. DGPS configurations must be reset and 10 minute wait for full DGPS performance is needed for each power cycle. I'll post results from antenna swap test when I get it run. Antenna brackets on both tractors are home made, EZSteer seems to like their position at front center of cab roof, both tractors EZ steer very well. |
