| It is doubtful that the pivot transport book will be updated this late in the season.
On percent overlap the acceptable range is 50 to 100%. The percent represents how much overlap must be present before a section or sections are turned off. The default setting is 100%.
The lead time is defined as this. This setting adjusts for any distance between the vehicle GPS location and the location of the product drives. If the product drives are stopping before they reach the field area already planted, add or increase the lead/lag time. If the product drives are stopping after they cross into the field area already planted, decrease the lead/lag time. The acceptable range is 0 to 5.0 seconds in 0.1 second increments.
As Torn said the Bar Distance is under Toolbox/Configuration Setup. Note: On CIH autoguidance tractors use the calibrated GPS location when making the measurement.
Edited by GPSNUT 4/15/2008 05:42
