North west MN | I did something like you are trying to do only I needed a relay that when seed command was seeding it would send voltage to one side of a Hydralic solonoid valve and when seed command was shut of it would power the other side of the Hydralic solonoid valve. You could use the same relay just would only use the one side. http://order.waytekwire.com/IMAGES/M37/catalog/220_061.PDF http://waytekwire.com/ is where I got mine it is a single pole double throw relay.
Edited by Mbmaring 4/14/2008 19:04
(Hella-Relay.jpg)
Attachments ---------------- Hella-Relay.jpg (9KB - 119 downloads)
