Search Forums | Classifieds (2) | Skins | Language
Raven control valve wiring for bypass
Scott (OSU)
Posted 4/4/2008 08:43 (#349735)
Subject: Raven control valve wiring for bypass
Dalton, OH
I'm setting up a Raven 440 setup that an Insight monitor will be running. You guys are probably sick of all of my questions!! Anyways, I will be putting the control valve in the bypass line. In the Raven manual it says I need a reverse polarity cable when the control valve is in the bypass line. I'm having trouble getting this cable. I was wondering can I just switch two wires and make this work without the acutal cable? I assume because it is a reverse polarity cable that's all they are doing. Any help with this would be apreciated!!
Thanks,
