Posted 4/4/2008 01:33 (#349612 - in reply to #349329) Subject: RE: Tried my new Boom Pilot today
What is the process you used to test the accuracy of the BoomPilot? How are you deciding whether the timing is set correctly? We put water in the tank and then used terrace tops to simulate the outside of a field. We sprayed around that area and every time we ran over the top of the terrace we watched to see if it shut off at the correct time. Is that a similar process to what you are doing?
